[?]: how import step7 xml file with eplan?
masscer
Anyone had import step7 xml file and generator the PLC schematic diagram?
venix
Hi!
If this is what you asked ...
The problem with all the eplan *.xml files is that they do not have function templates.So if you import them they will be shown in Parts management but you cannot use them in schematics.
You will get a error message wich will tell you that the selected macro not have a function template.
I don't know how to fix this problem.
I use macro projects instead part management.
