Hi I am new using PLC AB, before i using Twido by schneider.
now i want to start learn about AB.
does any one have tutorial or document about communication using Rs Emulator,
or i can say how to configuration between PLC AB and RS Emulator.
Thanks for the attention...
i really need this cos i had new project using AB PLC.
[?]: how to use RS Emulator ?
wahyudi_bc212
jap_td03
Re: [?]: how to use RS Emulator ?
you didn't show us which kinds of AB PLC you are using. But there are some general information may help you:
- imaging that your PLC simulator is a virtual PLC.
- you need RSLinx to connect betweeen your software (RSLogix500, RSlogix 5000,...) to PLC
- Select drivers (in RSLInx) for your PLC correctly.
- when the simulator run, you should see or can browse from RSLinx or PLC software.
RSLinx is like a bridge, you should configure it correctly.
good luck!
good luck!
ageofking
Checkout this link to get your software to link up with your RS emulator.
http://www.plcdev.com/a_quick_tutorial_ ... lator_5000
wahyudi_bc212 wrote:Hi I am new using PLC AB, before i using Twido by schneider.
neuhauser1234
I put a short explanation in
http://www.plc.net.ru/viewtopic.php?t=10014
I can give you more info if you need it
