I'm new in PID controllers
I use siemens continuous PID controller FB41 to control the dosing of H2SO4 to adjust the PH of the water but I can't get the right PH.
and I use same controller also to control the flow by opening and closing control valve and i can't get the right flow.
can you help me with this
thank you all
[?]: PID controller FB41 to control the dosing of H2SO4
...usualy in CIP systems I used dosing for one component two regulators:
once is TonToff controler which is working in Ton time and not working in Toff time, and second controller are SPonSPoff which activate TonToff function if PH is not enough...
So with this controllers I have good regulation, but my dosing pump are impulse pump.
Re: [?]: PID controller FB41 to control the dosing of H2SO4
hi all,mohammedhhh wrote:I'm new in PID controllers
thank you all
I Think the problem is not in controllors but in studying of system.
as you know the diffusion take time so if you increase the time of integration you get more stability of your process.
concerning the flow , if you have the differential pressure (and the flow ) you can choose the right valve. then the system pressure (close off pressure) emporte you to the right selection of actuator of valve.
finaly you can start programming.
..depends which system you use...In my example I have long time to caustic come from object of cleaning, so I used mentioned metod...if you make some drawing of your system it will be easier to see what you exactly need...so please make drawing of your regulation circuit..mohammedhhh wrote:thanks for reply
but can you give me more details?
I think you all are speaking about neutralization (or pH controlling in general). So mentioning PID controllers makes me think about neutralization in flow (without any tank or vat). If so there's nothing to do with circuit filling and related time.
Author should properly adjust regulator, deadbands etc.
Too few information provided so don't expect a reliable answer.
Regards.
Regards.
FB41 for pH Control
How about clamping the loop output Hi/Lo limit. It may help
This is classical example of time lag (time delayed) control system. For that purpose I don't think that PI or PID controller will help You. 'I' action will lead You to oscilation in pH because of time lag between control and measure point. My advice is to use 'P' controller but with variable gain because flow rate vary 6 times. That mean that for gain for 400m3/h will be insuficient for 2400m3/h flow. You should make some experiment to see what is the best gain for wich flow and than adapt gain of P controller to apropriate flow rate. I supose You measure the flow.
regards
regards
