Is it possible to access S7300 PLC to download project
or to be online with when you are connected Simatic Panel for example through Ethernet?
Panel and PLC are connected with MPI/DP.
[?]: Is it possible to access PLC through HMI
eway
eway
Yes, I have seen on Siemens support site that it should have S7 routing capability but it doesn't have as you said.
Here it is written which modules support S7 Routing function: http://support.automation.siemens.com/WW/view/en/584459
