I've start the "EPLAN Electric P8 1.9_ Dongles_Emulator"
Then I install the driver, after that I start the Service,
then I open the "Dumping"-Window, but in this I found no other button.
In the window "EMULATOR" the field "Licensed Dongles" is empty.
But there is an original Dongle on the USB-Port and EPLAN P8 works with this Dongle.
I'll try to dump the original key for use with the emulator.
Who can tell me the correct way to dumping an original dongle for P8???
Thanks...
Croco
