i have Mobile Panel 277 B and 2GB Kingston Elite Pro SD-CARD for message Archivs.
The Panel detect the Card but, i can not read/write.
The write Protection is off, FAT16 on a primary Partition.
I have the SD-card with SDFormatter V2.0.0.3 formated.
The same, no access under WinCE5.0/WinCC Flexible Image V1.1.0.3.
The siemens-suppert write , we must use the original siemens SD-Cards or MMC-Cards.
Has anybody a answer for this Problem?
[?+]: Mobile Panel 277 B and notSiemens SD-CARD
TitusII
TitusII
Yes, i am sure that alls configured. On MP 370 and MP377 we use Kingston Elite Pro CF 2GB without Problems, only on Mobile Panel 277 B we have this Problems.
Has anybody a Mobile Panel 277 B with SD Card (not original siemens) in use?
Its only a SD-Card, not SDHC.
Features / Benefits
* Capacities* — 2GB**
* Speed Rating*** — 2GB - 50x: 8.2MB/sec read — 7.7MB/sec write
* Dimensions — 0.94" x 1.25" x 0.08" (24mm x 32mm x 2.1mm)
* Operating Temperature — -13º F to 185º F (-25º C to 85 º C)
* Storage Temperature — -40º F to 185º F (-40º C to 85º C)
* Voltage — 3.3v
* Compliant — with the SD Card Association specification
* Small — about the size of a postage stamp
* Secure — built-in write-protect switch prevents accidental data loss
* Simple — as easy as plug-and-play
* Reliable — lifetime warranty †
* Economical — low power consumption is easy on device's batteries
Kingston Elite Pro Secure Digital Part Numbers:
SD/2GB-S
TitusII
TitusII
OK, all problems resolved.
First Step:
format a new SD-card (not SDHC) with
http://panasonic.jp/support/global/cs/s ... atter.html
(works with all Manufacturers)
Second Step:
open the Explorer and create a file on SD-Card, if this is possible, all ok,
If not check the write-protection on the card, check the Hardware-Control for the write-protection at the Card-Slot in the Panel (that was my problem,
the contacts were bent)
tested with Kingston Elite Pro 512MB, 1024MB, 2048MB and Panasonic 256MB SD-Cards
First Step:
Second Step:
