[?]: Step7 -> How to generate a source from a F- block
Can anyone tell me how i can generate the source of a F block, or otherwise how can i generate F-block's from a source
Re: [?]: Step7 -> How to generate a source from a F- bloc
Sjonnie aus holland wrote:Can anyone tell me how i can generate the source of a F block, or otherwise how can i generate F-block's from a source
Hello
Create sources files from FC, FB, DB.......blocks
Just insert source in your S7 project and make compile and will receive new block.
regards
Create FC, FB, DB.......blocks from source1.In the program editor, select the menu command File > Generate Source File.
2.In the dialog box, select the source file folder in which you want to create the new source file.
3.Enter a name for the source file in the text box.
4.In the "Select STEP 7 Blocks" dialog box, select the block(s) which you want to generate as the given source file. The selected blocks are displayed in the right list box.
5.Confirm with "OK."
One continuous STL source file is created from the selected blocks and is displayed in a window for editing.
regards
Hello
See in manual: http://support.automation.siemens.com/W ... en/2201072 how this block can be change, add and create new.... Procedure is not simple like normal FC or FB...
regards
regards
