Hi All..
Where i can find the documentation of old SATTCON PLC 60-50, 05-20? and the programming software also..
Regards
Ciwa
Request: ABB old SATTCON PLC 60-50, 05-20
i have this, great-grandfather of the PLC.
big diesel/fuel engines ABB / Wartsila ?
[dead] :/114444417/DOX10.rar.html
password for programing = dox10
if you want disks of instalation see this site:
http://www.cnczone.com/forums/showthread.php?t=39799
disk 4 is master for 5-15 (10 and 20)
disk 5 is master for 115-125
for 35 ?
the cable, although i do not remember very well is RS232 simple 2-3, 3-2, 5-5
edit:
later v3.4 for 5-15, 35, 100 and 200
most
search with google some pdf but no good manualDOX10 is build for DOS. It works in WIN95 an Win89. The best way to install is just to copy the hole directory in to 95/98 from a dos-system. You should also copy the Dox10.sys directory to 95/98
In the root C: should you have a file Config.sys. Edit the file like :
device=C:\windows\command\display.sys con=(ega,,1)
;Swedish keyboard and letters
Country=046,850,c:\windows\command\country.sys
Device=c:\windows\command\ansi.sys
;com1
Device=c:\dox10.sys\v24.sys R2048 S255 C1
;com2
Device=c:\dox10.sys\v24.sys R2048 S255 C2
Files=25
Buffers=25
Edit autoexec.bat like this:
@IF EXIST C:\Dox10\running.dox del c:\dox10\running.dox
The best thing is to run it in dos-mode. It is possible to run in windows, but in that case you have some problems with send and receive. You also have to make some changes in propertis for Dox10.pif.
It is possible to run Dox10 in 2000 or XP, but there is a lot of settings you have to do. I have tryed but not succed, I beleave that the problem spells DELL. I have the settings some where, but cant find them right now.
If possible use an old computer 286 / 386 works fine.
for 35 ?
edit:
most
Dox10 Newer version
Hi
Thanks for your link for dox10 . i am using 200 CPU serries , as i checked new version of dox10 must be used . is it correct ? could you provide me by newer version such as 3.4 ?
Waiting for your comments
