Download EDZ EPLAN page
Тools, Elcad, Eplan, ...
WinderJester
Post by WinderJester »
Hi!
Previously, when logging into the following link on the eplan page, the manufacturers' edz packages were listed and you could download them, but the page has now been closed.
https://www.eplan.com.mx/servicios/desc ... /download/
I have some links that you can download without having to register by just entering the URL, for example the following:
https://www.eplan.com.mx/fileadmin/cloud/5443/edz/2.9/Autosen.edz
And I have been able to rescue some others, I leave you the capture, only the name in the link is replaced as it is in the image and it can be downloaded, the link is case sensitive:
And I would like to know if you have any links, for example I am looking for the Delta package but I have not been able to find it.
I am leaving this here in case it is useful to you, and I would appreciate it if you could help me find Delta.
Thank you very much.
Regards!
Nmac
Re: Download EDZ EPLAN page
Post by Nmac »
Hey WinderJester, (nuser) Looking for the same type of files, after a little more search :search: inside the forum i've found a post with a BIG database access through a Torrent. Check this post.
viewtopic.php?p=102949&hilit=eplan+ezd#p102949 (usearch)
There is Delta edz files inside. Just select them
LithalethuYotsi
Post by LithalethuYotsi »
Hi NMac
You're a star (pgood) (tyou)
