Hello everybody !
Win10 Pro ver.1909 build 18363.592 and WinCC 7.4 SP1 are installed on the PC.
I want to use the "polygon tube" graphical object (GO) in the "Graphic Designer".
I take it from the "Standard" library, I put it horizontally, but its vertical size is too large. How to reduce it ?
In addition, the "pipe" is inserted into the "Graphic Designer" field at an angle of 45° for some reason ?
Maybe because of this it is not possible to reduce the size vertically?
Is there a "tube" in WinCC with changeable dimensions ?
How to reduce the vertical size of a " tube " in "Graphic Designer" ?
Alex3110
Alex3110
Re: How to reduce the vertical size of a " tube " in "Graphic Designer" ?
To reduce vertical size :
Properties > Styles > Line Weight
To change an angle to insert horizontally :
Properties > Geometry > Height = 0
