Maybe sometry connect this two version to one MS SQL database ? Use Edu + dataportal/epulse to dowloaded macro and next use a crack version and same MS SQL database to reading this macro. I try, I connect two eplan to one datables but... edu version say "other type" in crack vesrion, from second side same, crack version db is unreading in edu.
MS SQL base from Eplac 2022 edu and Eplan 2022 Crack
bercow
Hello.
Now is my problem, or is a next security, same like no export option in edu. Maybe is possible only copy some parts of table, like manual/script in M$SQL.
