E3 2021
evan838348
Re: E3 2021
Many thanks. This is really helpful.
Useful
Re: E3 2021
Hi, I have this problem:
I use my script, problem appear only after close and open a project and because I can't understand in what moment and what the reason
error damp
message: E - Error in function hntxtinf\get_txttyp(), ret = 2
https://wdfiles.ru/5c307e
https://wdfiles.ru/e5c742
Useful
Re: E3 2021
Looks like that I have problem with license, does anybody have the same problem?
evan838348
Re: E3 2021
Do you use the files in the 'crack' folder to active your license?
Before you use these files, use notepad edit the file of license.dat.
Change the host to your hostname. Hostname is your computer ID. You can ref. below's information to fine it.
https://www.quora.com/How-do-I-find-my- ... Windows-10
wangrenzhi
Re: E3 2021
How to modify the dat file and where to add the ID. Is Win10 a device ID or a product ID? The webpage you provided cannot be opened, thank you!evan838348 wrote: Sat Oct 22, 2022 12:13 pm Do you use the files in the 'crack' folder to active your license?
evan838348
Re: E3 2021
You can use 'Nodepad' to modify dat file. When you open the dat file, look at first line then you can see the text below.wangrenzhi wrote: Sun Oct 23, 2022 12:20 am How to modify the dat file and where to add the ID. Is Win10 a device ID or a product ID? The webpage you provided cannot be opened, thank you!
Replace XXXXXX as your device name
SERVER XXXXXX ANY
Start--> Settings -> System -> About.
In the section Device Specifications, there is an item labeled Device Name.
Владимир
Re: E3 2021
Если неизвестная ошибка появилась, то уже ничего вам не поможет. Не работает...
wangrenzhi
Re: E3 2021
After modifying the dat file, version 22.20 can be started normally, but after upgrading to version 22.22, an error is prompted and it cannot be started normally.
danky
Re: E3 2021
Hi!
I can help you with this (rc = ....). $20 - unlock one project! Project send to private messages.
I will unlock the first project and send it back free! I will indicate the card on which to send money by return letter for next projects!
I can roll back the project to the desired version. Each version back is $50.
Могу разблокировать проект. $20 - разблокировка одного проекта. Проект отправьте в личное сообщение.
Я разблокирую первый проект и отправлю вам обратно БЕСПЛАТНО! Я укажу номер карты для отправки денег для следующих проектов.
Могу откатить проект до нужной версии. Каждая версия назад - $50.
peewee
Re: E3 2021
does anyone else have an error while unpacking the archive with the file
cakal477
Re: E3 2021
please help me
The project opens, but after a few hours, when I close and open it, it gives the attached error.
most likely license error
https://imgyukle.com/f/2023/02/26/QTxsW6.png
lvs445
Re: E3 2021
2022 Zuken E3.series 2022 SP2 (22.30) на рутрекере
https://rutracker.org/forum/viewtopic.php?t=6333211-
lvs445
Re: E3 2021
Zuken E3.series 2023 Build 24.00 x64 2023 24.00 x64 [2023, NO RUS] [rutracker-6384444].torrent
https://rutracker.org/forum/viewtopic.php?t=6384444
