VNC Viewer for TP1200
skillerg9
Post by skillerg9 »
I need to connect from a TP1200 console to a Windows 10 computer to be able to view and control it.
Has anyone used any program on windows CE for that?
Is there any VNC Viewer or Remote desktop RDP application?
Thanks in advanced.
misa1515
Re: VNC Viewer for TP1200
Post by misa1515 »
Hello direct implemented in Siemens Comfort panels.
You need only enable this functionality (in control panel) and set access passwords (read only and read/write).
Then you can run VNC on Windows and access to HMI.
waynejonstone
Post by waynejonstone »
This one is working on almost all Siemens Panels.
http://efonvnc.sourceforge.net/
skillerg9
Post by skillerg9 »
misa1515 wrote: Thu Apr 07, 2022 5:54 am Hello direct implemented in Siemens Comfort panels.
I intend to do the opposite, connect from HMI to Windows PC.
Thanks.
skillerg9
Post by skillerg9 »
waynejonstone wrote: Thu Apr 07, 2022 7:42 am This one is working on almost all Siemens Panels.
I think this is just server and I need the viewer to connect from the HMI to the windows PC.
Tomorrow I will test.
thanks
waynejonstone
(sorry) You´re right this is only for accessing a panel from anywhere.
I usually use it on tablet during commissioning, so I dont have to walk back and forth to the HMI
