How to replace the connection with an Ethernet cable with wifi (cx-programmer and cj2m) or (sysmac studio and na5 hmi)?
I know that using a device such as a router / repeater / access point. But I don't know exactly how to configure it.
wifi connection cx-programmer and cj2m
euovitoteu
Re: wifi connection cx-programmer and cj2m
I often use a wifi connection between a CJ2 and the PC via a portable router. I set a fix IP address to the LAN port of the router, in the same range as PLC, I connect the PC to the wifi the router generates and that´s all. The PCs wifi is set to DHCP so that it could get the IP from the router.
