Morning!
I can't upload from PLC micro 850 2080-LC50-48QWB.
I can see the PLC using RSLinx Classic, I see the PLC's ip 192.168.1.11, I perform the correct procedure in the CCW but I am not successful.
I have already uninstalled and chosen ccw, I have also changed from version 12.00 to version 11.00 of ccw.
the attached fault log generated in both ccw version 11 and ccw version 12 is attached.
My PC's windows are Windows 10 home single linguage
https://drive.google.com/file/d/1F85tW2 ... sp=sharing
https://drive.google.com/file/d/1Mj1W5d ... sp=sharing
Can you help me?
Fault of upload PLC micro850 2080-LC50-48QWB
TcoSj
Re: Fault of upload PLC micro850 2080-LC50-48QWB
Hello! Have you tried to load and unload the program on the simulator?
