1. Differences between motorcycle helmets and construction helmet
The construction helmet is pretty lightweight, the average weight is around 300grams. This provides the best comfort with a lot of airflows around the head. The shell is mainly made from plastic and is molded simply. The main function of this helmet is to prevent injuries caused by falling objects in the construction site such as bricks or iron bars. There aren’t any straps, visor, or front and ear protection. The price of a construction helmet is just around 4-6 dollars.
The motorcycle helmet, on the other hand, is much heavier than a construction helmet due to many additional protection and materials. Depending on each type of helmet, you will feel a different level of comfort. Such a full-face will provide the best protection, but it is quite suffocating. A half-face is more comfortable as the fresh air can blow to your face. A motorcycle helmet is used for motorists who often ride at high speeds, so it must cover the whole head to avoid injuries from every side. It has the visor, styrofoam liners, chin straps, and polyester pads.
Polyester is the material that allows users to breathe while having the whole face covered. Additional protection also means the price of the motorcycle helmet is also much higher, usually 10 times more expensive than the construction one. The lifespan of these two helmets is also different. While the motorcycle hat can averagely last for years, the construction helmet is just for months. If your motorcycle helmet expired, and you are looking for a Bluetooth motorcycle helmet. You can refer to this source: https://helmetszone.com/best-bluetooth-motorcycle-helmet.html
A Snell, ECE 22.05, or DOT certification is required for motorcycle gear. Before being sold on the market, this motorcycle headgear is tested by dropping from a certain height at speed onto a steel ball. This is to test how well the shell absorbs impact from the road when an accident occurs.
All parts of a motorcycle helmet are designed for a certain purpose. The outer shell will prevent hard objects hitting your head and the soft lining inside are to absorb multiple impacts from the front, back, below, above or side. The visor will help in keeping bugs or rain from getting into your face and eyes.
2. The difference between Motorcycle helmet and cricket helmets.
For some starters, they are not the same. The first dissimilarity is the material. While Cricket helmets are made of Acrylonitrin Butadien Styren(ABS) plastic, while motorcycle’s are made of either ABS plastic, or Polycarbonate, or Aramid, or Fiberglass. Some cricket helmet models are now coming with additional protection for the back head and mouth. The mouth protection is formed as a cage covering the jawbones. The weight is quite the same, but the protection ability of the motorcycle headgear is better than the cricket helmet.
There are many types of motorcycle gear namely Bluetooth helmets, Modular helmets, Carbon fiber, Open-face, Vintage, and so on. They come out with various styles and designs, so that motorcycle helmets are not only a headgear but it is also a fashionable accessory. This feature also makes it more popular than other helmets.
If you feel this post is still not enough for you, then you can read more informative articles of HelmetsZone on Twiter at https://twitter.com/helmetszones.
