Hello everybody !
Anybody calculated variants by the price (with the same parameters CPU, HDD / SSD, RAM) :
1. Laptop + USB-MPI \ DP adapter + licensed software (STEP7 & WinCC + PLCSIM + WinCC RT keys) Pro v.15.1 "
VS
2. Simatic Field PG M6 Advanced with pre-installed the similar software v.15.1
What is the difference in price for the indicated HW and SW, or for the earlier one, if you calculated before ?
Simatic Field PG M6 - the price, for example, is about 7000 Euros (not in Germany).
If you chose option 1, then had U a lot of troubles to make a Lap Top like Simatic Field PG ?
Lap Top VS Simatic Field PG
Re: Lap Top VS Simatic Field PG
Both is OK, PG is too heavy, if you travels a lot......
It is also good idea that use a Virtual machine like VMWare in high performance laptop.
