HMI GT2715 connection of one panel with two PLC Q02H via a switch
beeaver
Good day! There are two Q02H controllers, they need to be connected to the same GT2715 panel via a switch. Is it possible to make so that from the panel it is possible to view and control the inputs and outputs of the controllers independently, even if part of them reminds the same, for example, output Y0 on controllers No. 1 and No. 2 correspond to different control objects. In the simulator, control is shared, although the settings of addresses, station numbers are different.
