I need to configure the IEC_REP block in DATASET mode from the side of the S7-400 PLC (client) and Siprotec 6MD664 (server). How to correctly enter the address tag in the input "address" of this unit? How to use it in a redundant system? The cyclic IEC_ALARM and IEC_RD_BO blocks work without problems.
The address of the signal 'CTRL / LLN0 $$ ST $$ LEDRs' in the IEC_ALARM and IEC_REP block. The time stamp and value is updated in IEC_ALARM, but not in IEC_REP. I have put in two test projects for devices that I want to connect using the 61850 protocol (Siprotec and S7). Version PCS7 v8.0, DIGSI 4.85
thanks for the help
screen cfc
http://prntscr.com/mqqwof
