I have a Micrologix PLC 1500 on which channel 0 is free. I need to take this PLC in scada via ethernet module any one can suggest a suitable module for this??
currently I have searched and found two modules which are
1761-NET ENI
prosoft -PLX51-DF1-ENI
Which one will be reliable if some one used this please suggest
Micrologix1500
theplcgeek
Re: Micrologix1500
The question is, what is the SCADA package you are talking to and what protocol do you intend on using?
Can it poll the PLC or does the PLC have to write data to the SCADA?
sandumon84
Re: Micrologix1500
We are going to use Zenon copadata software it will support AB drivers and modbus tcp/ip also it is capable to poll from PLC
Regards
Sandeep
Regards
Sandeep
