Hello there
I need the program I wrote below.
This program is a program that tells Mitsubishi servo motors the strength to write to the encoder. Encoder type OSA16,OSA17,OSA18 vs...
 I can not find anywhere.
Give the the name of the program MOTID VER.1.00 if you have in your hand are you sharing?
Thank you...
						[?]: Mitsubishi servo motor encoder software
				setmedical
				setmedical
Re: help me! Mitsubishi servo motor encoder software
update help me???
				setmedical
update help me??? Mitsubishi servo motor encoder config software motid.
				setmedical
Mitsubishi (Motor ID writer) software. Servomotor encoder firmware.....
				EvgenyAly
Little chance, but I'll try to find out . The EEPROM 25L160 encoder OSA676S5AS failed , there were engine settings. Maybe who knows where to get the firmware?
				kamol_p
You Can be done this problem finished?
