i have hmi omron nt600s-st211 ev3 in my factory and have problems in touch ]
i want to change it to delta dop if some one helps me to make adresses of input and outputs and data entering
need help for hmi omron
wildpikachu
Re: need help for hmi omron
What CPU are you using?
wildpikachu
have you selected the cqm series under your communication settings?
If not then go to the options tab and select communication settings then select "omron" under the manufactures options and then select "c/cpm/cqm series" under the series option.
once that is done you should be able to set the memeory path for your PLC tags on the HMI.
ahmedmh
there isn't problem with communication with the new hmi
the problem is how to set the memory data entering in the new hmi dop delta
wildpikachu
I've pm'd you my email address.
Would you mind sending me your DOP file?
