Hello everyone,
I was wondering if you could help me with something i'm trying to do...in WinCC(Tia Portal V13)
i have some output fields that display real numbers..
what i'm trying to do is make them numbers appear with separators e.g 100.000 instead of 100000.
I'm not talking about decimals but about thousand separators...
i did a lot of research and the only thing i found was the use of analog display(external) which is a wincc 7.3 feature only....
Do you have any idea of how could i make this happen?
Any help would be greatly appreciated...
Thank you very much in advance!
[?]: Thousand Separator in WinCC (Tia Portal)
Hellion
