DBx.DBDxxx to output
Hello ,I need a help in transferring a DBx.DBDxxx to an output, in the form of a Boolean signal, could you help me out?
Re: DBx.DBDxxx to output
if You use STL than:
a DB1.DBX0.5
= Q0.1
Upper code You can easy convert to LAD or FBD
regards
a DB1.DBX0.5
= Q0.1
regards
I want to transfer a double word because my db is DB8.DBD462
Could You clarify Your problem. DBx.DBDx is DOUBLE WORD data, which is 32bits wide.
l dbx.dbd xxx
t qd yyy
t qd yyy
So you can do this way in STL.
L DB8.DBD462
T QD4
(You do only two statement code)
But all the Bit address start from DB8.DBX462.0 till DB8.DBX465.7 will write to Q 4.0 till Q 7.7
L DB8.DBD462
T QD4
Exactly.
Just experience share here
To create couple FCs and call them when necessary. It can be also work for some mathematical calculation
