When on the wi-fi connection NetToPlcsim sees it the first of its IP 192.168.0.20 .. disable wi-fi, the utility sees 127.0.0.1, even though the real ip Ethernet 192.168.1.2.... I connected plcsim and NI OPC server 2013 in opc client "NI OPC server", pass the variable - "good" , but for some reason, Matlab(like OPC client) sees all available server but can not connect, so it is with the client OPC Scout ..
If I disable wifi on the laptop and is written in the the OPC server and nettoplcsim address 192.168.0.65, such as 192.168.0.5, then offers me the network address of 127.0.0.1 and OPC client variables are "bad."
If you switch on wi-fi connection (address 192.168.0.20) then offers me the network address of 192.168.0.20, I prescribe it and OPC server variables are "good" only for the OPC client NI Server, the server for other clients NI(OPC Quick client) is listed, but not It is connected to it and does not output variables.
