Help to get Studio 5000 software please any version is good.
Asolis
Hello every one.
Some one can help me, posting a link to download Studio 5000 any version it is good.
Regards.
Regards.
pipikikiki
RMFC301980
Re: Help to get Studio 5000 software please any version is g
hi.I would like to download the studio 5000, but the link do not work.
pipikikiki
engr_kierrosita
What license to use in the software in the links?
tacocat
https://mega.nz/#F!Nxo1EKJQ!GTL7loUdjVWNBQ4BdbdGSQ[/quote]
Good morning,
I followed the instructions as close as i could for V29. I can edit files but when i try to create a new file it crashes and displays this error. "Unable to load logix designer: failed to initialize factorytalk activation ( error code 8 ). there are several files im not sure what to do with.
can anyone help me please.
Good morning,
aungorng
Hi Tacocat,
I am downloading and will try later but I found "HOSTDISK_SERIAL_NUM=265F3E19_Concurrent_20140430025452571.lic" in ver.19 also. Have you tried putting it in C:\Users\Public\Documents\Rockwell Automation\Activations as last step in instruction.txt ?
t-jay
Hi .. any update sir??.. i try to installed v30. ..but when i try to create a program an error appeared afinfo.dll not found can you please help me how to fix it. ..and how to activate factory talk activation manager thanks in advance ....
pipikikiki
Dear Mr T-Jay,
Refer here, maybe useful for you.
http://fake/19-vt31.html?post ... &start=270
Regards!
Regards!
t-jay
Thanks you sir. .
Lamatrian
Hi Tacocat,
I'm stuck in the same situation. Did you succedeed in any way?
Asolis
Hello every one
I just install normally and everything works well.
About the license, I just reset the factory talk activation manually
engr_kierrosita
Good luck
engr_kierrosita
Good luck
Cntrlmation
Hello all,
Anyone with info. on how to activate Studio - Logix designer v30 please?
The link provided by "pipikikiki" below doesn't seem to be working anymore as it takes me to a login page that doesn't accept my login credentials.
Help much appreciated!!
cntrlmation
cntrlmation
pugacz
What does mean "reset the factory talk activation"?
FT activation manager does not contain items like "reset activation".
how exactly do it?
how exactly do it?
mailmat
just reset activation manually
Ahmad Hammad
same situation here. any luck?
ElMaes38
Re: Help to get Studio 5000 software please any version is good.
Hello all,
I'm trying my luck here since I got the same error with the afinfo.dll.
Hope someone succeeded to solve the issue ?
Gregory
Gregory
TcoSj
Hi Gregory,
I am stuck in the same situation. Have you found a solution to your problem?
TcoSj
I solved the problem with " afinfo.dll ", downloaded the software from another source
https://drive.google.com/drive/folders/ ... I5LB39AvqP
or from this
http://www.100-sf.com/Rockwell.html.
or from this
