Folks,
I've not had this problem before and it is likely something stupid that I did to cause this...
Below is the error message I get when I try to create a runtime application (.MER) for my PV Plus 7 Standard (Using firmware 7)
__________________________________________________ _____________
*** Start RSLinx Enterprise Conversion Messages ***
ERROR: Unsupported driver detected. Driver name = "RSLogix 5000 Emulator". Description:
Only the Ethernet driver is supported by PanelView Plus 7 Standard Machine Edition applications. Only the Ethernet,
Serial DF1 and Serial DH485 drivers are supported by Compact Machine Edition applications.
*** End RSLinx Enterprise Conversion Messages ***
Validation completed with errors. The runtime application has NOT been created.
I haven't had this happen before; I was trying to setup the emulator awhile back so I could run in design time from my desk, but I don't know what to do or how solve this problem...
Hope you can help...
Thanks so much in advance...
John Whited
FactoryTalk View Studio ME (9.00) ERROR THAT I CAN'T FIGURE.
JohnnyQuanex
