Hello, i'm newbie and cannot understand plc
Can someone help me to create am example program for the digital alarm to level switch because I am now commissioning at site and I do not understand plc
I use the ab plc 1769-L16ER-BBIB
When level switch tkxx on--->Lamp indicator tkxx on----->alarm on
When operator -push ack-------->alarm off, Lamp stay on(if level switch tkxx off Lamp tkxx off)
And when operator -push lamp test ---->all lamp indicator on----->alarm on and operator -push ack-------- >alarm off and operator -push reset------>all lamp indicator off
Total level switch 7 instrument, 7 lamp indicator,1 buzzer, and 3 -push Button for ack,lamp test amd reset
Alarm digital for commissioning urgent
almaz78
Re: Alarm digital for commissioning urgent
Wow! you are very brave man. You can c0mmission somethimg that you dont know.
duckman
My thoughts exactly when l read it 4 days ago.
PLC's must be very easy to use and you can't cause a problem when you alter the safety code or any other code
Radithadi
This is urgent, because the previous engineer who made the program plc and I were making scada it to this prjectalmaz78 wrote:Wow! you are very brave man. You can c0mmission somethimg that you dont know.
but now he has resigned from where I work
and a customer asked for an alarm to switch their level
Can you give me a little direction, I'm sure it's very helpful
Radithadi
I almost finish his scada and for digital alarm I tried to make a program using ALMD but still experiencing problems and it was very frustratingduckman wrote:My thoughts exactly when l read it 4 days ago.
Radithadi
Radithadi wrote:Hello, i'm newbie and cannot understand plc
Radithadi
This project was done by two engineers
one that makes plc program and one that makes the display scada (i)
which makes the program plc has resigned before commissioning and me who have to go to the site because I made scada
but disite so much trouble and alarm is one of them
I tried to solve it one by one before 14 later
