How to access Modbus TCP Conection Status/IP via C in WinCC
Hi dear experts. According to the attached picture I want to access the status and connection driver IP address of my Modbus TCPIP channel drivers via C-Script in WinCC. Can anyone suggest me a function or a script code.
Re: How to access Modbus TCP Conection Status/IP via C in Wi
Thanks a lot for the reply but this link is not about accessing that parameter via c-script.
It is about getting status of connection via C-sctipt
#include "apdefap.h"
int gscAction(void)
DWORD dwState = 0;
GetTagSWordState ("External_tag_1", &dwState);
if (dwState == 0)
//Tag status OK
printf ("Tag status Ok: [Statuscode (hex):%X]\r\n",dwState);
SetTagBit ("Trigger", FALSE);
SetTagBit ("Trigger_connection_interrupted", FALSE);
else if (dwState&0X0001)
SetTagBit ("Trigger_connection_interrupted", TRUE);
else
//Tag status deviant
printf ("Tag status deviant: [Statuscode (hex):%X]\r\n",dwState);
SetTagBit ("Trigger", TRUE);
return (0);
Thanks dear Schtiel.
Do you have any idea about changing IP address of modbus TCPIP driver ia C-script?
This is a sample of changing IP address of connection to CP 443-1. May be it would give an idea how to to do the same for Modbus TCP
int gscAction( void )
// WINCC:TAGNAME_SECTION_START
// syntax: #define TagNameInAction "DMTagName"
// next TagID : 1
#define TAG_0 "@NewConnection_1@AlternateConnectionAddress"
#define TAG_1 "@NewConnection_1@ConnectionEstablishMode"
#define TAG_2 "@NewConnection_1@ConnectionState"
#define TAG_3 "@NewConnection_1@ForceConnectionAddress"
// WINCC:TAGNAME_SECTION_END
// WINCC:PICNAME_SECTION_START
// syntax: #define PicNameInAction "PictureName"
// next PicID : 1
// WINCC:PICNAME_SECTION_END
#pragma code("msrtcli.dll")
#include "msrtapi.h"
#pragma code()
#pragma code( "kernel32.dll" )
VOID GetLocalTime(LPSYSTEMTIME lpSystemTime);
#pragma code()
static int Mld_Main = 0;
static int Mld_Res = 0;
DWORD ServiceID = 0;
static BOOL InitFirst = TRUE;
static MSG_RTCREATE_STRUCT MsgCreate;
CMN_ERROR Error;
if ( InitFirst == TRUE )
memset( &MsgCreate, 0, sizeof (MSG_RTCREATE_STRUCT) );
MsgCreate.dwMsgState = MSG_STATE_COME;
MsgCreate.wTextValueUsed = 1;
sprintf( MsgCreate.mtTextValue[0].szText, "NewConnection_1" );
SetTagChar( TAG_0, "IP,192.168.1.12,,0,2,02" );
InitFirst = FALSE;
if ( GetTagDWordWait( TAG_1 ) == 0 )
Mld_Main = 0;
Mld_Res = 0;
return 0;
else
GetLocalTime( &MsgCreate.stMsgTime );
MSRTStartMsgService ( &ServiceID, NULL, NULL, MSG_NOTIFY_MASK_ARCHIV, NULL, &Error );
if ( GetTagDWordWait( TAG_2 ) == 0 )
if ( GetTagDWordWait( TAG_3 ) == 0 )
if ( Mld_Main == 0 )
MsgCreate.dwMsgNr = 1012222;
MSRTCreateMsg( ServiceID, &MsgCreate, &Error );
Mld_Main = 1;
else
if ( Mld_Res == 0 )
MsgCreate.dwMsgNr = 1012224;
Mld_Res = 1;
SetTagDWord( TAG_3, 1 );
else
SetTagDWord( TAG_3, 0 );
else
if ( ( Mld_Main != 0 ) || ( Mld_Res != 0 ) )
Mld_Main = 0;
Mld_Res = 0;
MsgCreate.dwMsgNr = 1012223;
else
MsgCreate.dwMsgNr = 1012225;
if ( ServiceID != 0 )
MSRTStopMsgService ( ServiceID, &Error );
return 1;
