When I uploaded the project(in simatic manager V5.5) the symbols and comments weren't shown on my laptop, I need to retrieve or found the file source of the project
Thank you
File source
From "Programming with STEP 7" manual:
When uploading blocks from the CPU to the programming device, remember that there are two distinct situations:
1. The user program to which the blocks belong is located on the programming device.
2. The user program to which the blocks belong is not on the programming device.
This means that the program sections listed below, that cannot be downloaded to the CPU, are not available. These components are:
- The symbol table with the symbolic names of the addresses and the comments
- Network comments of a Ladder Logic or Function Block Diagram program
- Line comments of a Statement List program
- User-defined data types
Re: File source
Can I retrieve the file source !!???
Thank you very much
Re: File source
Without the source project the answer is NO, you can't
Re: File source
HI
How i can display accessible nodes ??
there isn't any display when i click on accessile nodes
what' s the problem please !!!??????
THANK YOU VERY MUCH
THANK YOU VERY MUCH
