I'm in my last year of studing, and I have realise my project in automation and supervision.
so, in the society, we have more than 20 machines commanded by 2 motors , these motors are controlled by 3 Variable Speed Drives.
The problem is that i don't know which software of "automation and supervision" must I use to program that and create an easy interface ? can I use RSLogix500 ?
Thank you for your helps.
Question Please
yaqui
Re: Question Please
Hi, If you try with TIA Portal, you will be able to create a PLC and HMI-SCADA program, and by the way you can use PLCSim to simulate everything.cavayiro wrote:Hello,
With RSLogix, you will create a PLC program, and with PanelBuilder32 / Factory Talk View you will able to create a HMI Program.
Good Lock
