Help please I upload the program from existing Quantum PLC but after uploading when I try to rebuild the project it gives me error saying "Type not found in Types Library". There's a lot of EFB type that are not on the library.
SHLR Type not found in Types Library,
RTSNDI16 Type not found in Types Library,
WORD4_TO_DT Type not found in Types Library,
TAKTG Type not found in Types Library,
RT_REG Type not found in Types Library,
TXSNDW8 Type not found in Types Library,
TXSNDW16 Type not found in Types Library,
B3IN1 Type not found in Types Library,
MOVE_INT Type not found in Types Library,
RT_SEND8 Type not found in Types Library,
TAKT Type not found in Types Library,
B3BEF Type not found in Types Library,
RTSNDG16 Type not found in Types Library,
EZKOM Type not found in Types Library,
TXSNDI16 Type not found in Types Library,
TXSNDG16 Type not found in Types Library,
B3IN2 Type not found in Types Library,
MOVE_BOOL Type not found in Types Library,
MOVE_REAL Type not found in Types Library
Process failed : 1 Error(s) , 0 Warning(s)
Yes Sir you're right the supplier for this PLC was Cegelec. But what's the best thing to do because I have to modify this PLC by adding NOE cards and additional network and it requires Rebuild all project.
I hope you are not from SWCC? Nobody will provide B3000 libraries also not for fee. The only one right way to get the libraries is to ask Cegelec as supplier of plant.
