Public WithEvents oGroup1 As TagGroup
Public vidrios1, vidrios2, vidrios3, vidrios4, vidrios5, vidrios6, vidrios7, vidrios8, vidrios9 As String
Public str_vidrios1, str_vidrios2, str_vidrios3, str_vidrios4, str_vidrios5, str_vidrios6, str_vidrios7, str_vidrios8, str_vidrios9 As String
Public Sub Display_AnimationStart()
Dim TagsInError1 As StringList
On Error Resume Next
Err.Clear
If oGroup1 Is Nothing Then
Set oGroup1 = Application.CreateTagGroup(Me.AreaName, 500)
If Err.Number Then
LogDiagnosticsMessage "Error creating TagGroup. Error: " _
& Err.Description, ftDiagSeverityError
Exit Sub
End If
oGroup1.Add "[0]comm_furnace_glasses[0]"
oGroup1.Add "[0]comm_furnace_glasses[1]"
oGroup1.Add "[0]comm_furnace_glasses[2]"
oGroup1.Add "[0]comm_furnace_glasses[3]"
oGroup1.Add "[0]comm_furnace_glasses[4]"
oGroup1.Add "[0]comm_furnace_glasses[5]"
oGroup1.Add "[0]comm_furnace_glasses[6]"
oGroup1.Add "[0]Glass[0]"
oGroup1.Active = True
oGroup1.RefreshFromSource TagsInError1
End If
End Sub
Private Sub oGroup1_Change(ByVal TagNames As IGOMStringList)
Dim oTag11, oTag21, oTag31, oTag41, oTag51, oTag61, oTag71 As Tag
Dim oTag100 As Tag
Dim str_bits1 As String
If Not oGroup1 Is Nothing Then
Set oTag11 = oGroup1.Item("[0]comm_furnace_glasses[0]")
Set oTag21 = oGroup1.Item("[0]comm_furnace_glasses[1]")
Set oTag31 = oGroup1.Item("[0]comm_furnace_glasses[2]")
Set oTag41 = oGroup1.Item("[0]comm_furnace_glasses[3]")
Set oTag51 = oGroup1.Item("[0]comm_furnace_glasses[4]")
Set oTag61 = oGroup1.Item("[0]comm_furnace_glasses[5]")
Set oTag71 = oGroup1.Item("[0]comm_furnace_glasses[6]")
Set oTag100 = oGroup1.Item("[0]Glass[0]")
m_vidrios.str_bits (str_bits1)
str_vidrios1 = str_bits1(CStr(oTag11))
str_vidrios2 = str_bits1(CStr(oTag21))
str_vidrios3 = str_bits1(CStr(oTag31))
str_vidrios4 = str_bits1(CStr(oTag41))
str_vidrios5 = str_bits1(CStr(oTag51))
str_vidrios6 = str_bits1(CStr(oTag61))
str_vidrios7 = str_bits1(CStr(oTag71))
Err.Clear
End If
txtHorno.Value = "Mid(str_vidrios1, 1, 31) & Mid(str_vidrios2, 1, 31) & Mid(str_vidrios3, 1, 31) & Mid(str_vidrios4, 1, 31) & Mid(str_vidrios5, 1, 31) & Mid(str_vidrios6, 1, 31) & Mid(str_vidrios7, 1, 31)"
If Mid(txtHorno, 1, 1) = "1" Then
oTag100.Value = 0
End If
If Mid(txtHorno, 1, 1) = "0" Then
oTag100.Value = 1
End If
End Sub
I have some doubts , please help debugging it :
1) txtHorno is a name of string display object (which is VBA controlled) :
is it right???
should i write "" because this is returning a string???
should i write "txtHorno.Value =" or just "txtHorno ="
if not please tell me the correct way to write it, actually txtHorno is a string in which i want to move the above(function returned) value.
2)m_vidrios is my module name in which i have defined a public function so that i can use it in my form :
Is it a right way to call it???
The code of module named "m_vidrios" is :
Function str_bits(entrada As String) As String
Dim i, j As Integer
Dim Temp As Double
Temp = Abs(CDbl(entrada))
str_bits = "0000000000000000000000000000000"
i = 0
If Temp = 1 Then
str_bits = "10000000000000000000000000000000"
GoTo A:
ElseIf Temp = 0 Then
str_bits = "00000000000000000000000000000000"
GoTo A:
End If
For i = 31 To 1 Step -1
If Temp / 2 ^ i >= 1 Then
str_bits = Mid(str_bits, 2, i - 1) & "1" & Mid(str_bits, i + 1, Len(str_bits) - i)
Temp = Temp - (2 ^ i)
Else:
str_bits = Mid(str_bits, 2, i - 1) & "0" & Mid(str_bits, i + 1, Len(str_bits) - i)
End If
Next i
If Temp = 1 Then
str_bits = "1" & str_bits
Else:
str_bits = "0" & str_bits
End If
A:
End Function
3) oTag100.Value = 1
will update my PLC tag "[0]Glass[0]" high automatically or i have to write anything else???
VBA code problem...need ur help to find the bug
sachincool786
