Dear Experts!!!
I am facing one problem in FT View SE v8.0 :
I have 15 screens : 5 "are replaceable" with full resolution and other 10 are popup displays with half the resolution of that of Monitor and are "on the top" type. I have a buttons to go to those pop up screens.
Whenever I press any button to open any pop up screen the background screen becomes shorten and pop up displays works like they should.
i.e. whenever a pop up display opens, full background screen display suppresses automatically. Then i go to another full screen and then come to the main working full screen then it becomes ok.
This phenomenon occurs whenever a pop up display open.
Please help!!!!
Factroy talk SE v8.0 screen problem
NowanH
Re: Factroy talk SE v8.0 screen problem
It's difficult to repeat that behavior without knowing what method you are using for invoking the popup screens:
a) Are you using normal buttons, action is Run command and Press action is Display yourpopup?
b) Are you using VBA code?
sachincool786
NowanH
Some questions:
1. In the picture you uploaded, is the background display (the shrunken one) a separated display from the menu bar and the alarm banner?
2. What are the dimensions of the background display in pixels? What is the resolution of the client monitor?
sachincool786
Actually I have one header (the menu bar.... /DT), One footer (The alarm banner..../DB) and the main display (you can see the background)
Wheni press LOGIN button that pop up windows opens and the back image got shrunk all the time
The display is of 1020*760
The resolution of the screen is 1280*1024
sachincool786
This phenomenon occurs whenever a pop up display open (not VBA controlled).
Its a simple display open button ( not VBA controlled)
As you can see in the picture the back image is suppressed :-
http://postimg.org/image/c5um49c5h/
Normally it comes to full screen , its like :-
http://postimg.org/image/vtli1bd7f/
when I go to some other replaceable type screen and come back again to this screen, it becomes OK.
Here in this pic below, you can see the properties of the screen which is giving problem :-
http://postimg.org/image/gcqpkfb65/
