Dear Sr
I have a problem with a AEG ALU 200. Maybe you could help me.
I have connected to a ALU 200 using Dolog AKF and I have uploaded the program.
After that, when I try to go onling to see signals I always get the same error:
Definitions-Listen: SPS ungliehch PUTE.
(The content of PLC is different)
I don´t know what is happening becouse I have recovered the program from the PLC (SPS)
I have been reading than AEG ALU 200 doesn´t have memory and it uses an EPROM that it must be written with EPS 200.
If the AEG ALU is using a EPROM Can I go online to check signals ?
Could anybody give me some advice ?
I don´t know if the problem is the version of Dolog AKF.
Thanks in advance
Moisés Moreno (From South of Spain)
moi.tarifa@gmail.com
Help AEG ALU 200
Re: Help AEG ALU 200
Can you share Dolog AKF software ? I'm searching for long time.
