Wincc connection number?
gramsoup
The project use wincc server/client type. The communication have 12 connection by TCP/IP protocal. As Wincc run,the graph will flash and disconnect sometimes. But several seconds Wincc display will be ok. I guess the question is Wincc connection over 8 and need Simatic Net license.But I don't know which one license is need from SIMATIC_EKB. The Wincc version is 7.2 and Simatic Net is 8.2.
Info
- Faq & Info
Re: Wincc connection number?
With the complete implementation of the I IA licensing concept it became necessary as from SIMATIC NET Edition 2006 (V6.4) to distribute the license keys according to function with some SIMATIC NET PC software products.
For example, with SOFTNET S7 IE Edition 20** you get three license keys:
One SOFTNET S7 Basic Key SIFLNSIEPG* for PG/OP communication, which means communication is enabled in general.
One SOFTNET S7 Lean Key SIFLNSIESL* for the use of 1 to 8 connections over Industrial Ethernet.
One SOFTNET S7 Powerpack Key SIFLNSIESE* for the use more than 8 connections (9 to 64) over Industrial Ethernet.
