Hi all,
I have a SCADA system (Factory Talk) running at a plant and it has to exchange data with a remote PLC (CompactLogix) which is located at another plant. I thought of using VPN, but I've never used it before and I'm not sure if it fits to continuous data acquisition.
Any suggestion?
SCADA Access to a Remote PLC
neuhauser
Re: SCADA Access to a Remote PLC
How are you going to access the remote compact? somehow directly to the processor or through a server at the site?
Using a OPC server? RSLinx- used to have to have linx gateway to poll data remotely.
Most setups I've seen use a 3rd party opc tunneling package to make it simpler for firewalls, compressing data, etc.
longquan
Hi Everyone!
can Anyone help password to unprotected controlextendedlib 1.4.7 for compact control builder M version 5.1.1-2?
Thanks so much!
Thanks so much!
NowanH
I would suggest you to open a new post in the correct forum.longquan wrote:Hi Everyone!
Thanks so much!
