Подскажите,пожалуйста, кто знает. При обновлении firmware на 1769-L32E появляется следующая ошибка "[FAILURE] Transfer: Error #11006: Service cannot be performed while object is in current state." , как с этим бороться? CPU - новый.Ключ в положении Prog. Полный лог :
Help me please, who know any information. When i try to update the firmare on CPU 1769-L32E i see next error "[FAILURE] Transfer: Error #11006: Service cannot be performed while object is in current state." What it might be? CPU is a new, and key swith to Prog. Full log :
Flashing module with C:\Program Files\ControlFLASH2\\0001\000E\004D\PN-176967.nvs...
Path to module: AB_ETHIP-1\147.0.10.231\Backplane\0
Serial Number: 60604204
Current Revision: 1.17
New Revision: 19.15.25
[SUCCESS] Load Driver: C:\Program Files\Common Files\Rockwell\AB_ASA.DLL
[SUCCESS] Initialize Driver: C:\Program Files\Common Files\Rockwell\AB_ASA.DLL
[SUCCESS] Device Identify: Path = RSLinx API!AB_ETHIP-1 16 12 49 52 55 46 48 46 49 48 46 50 51 49 1 0, Instance = 1,
VID=0x0001, PT=0x000E, PC=0x004D, Maj Rev=01, Min Rev=17, SN=0x60604204
[SUCCESS] Load Script: C:\Program Files\ControlFLASH2\\0001\000E\004D\PN-176967.nvs
[SUCCESS] Program: Catalog Number = 1769-L32E/B LOGIX5332E, Serial Number = 60604204, Num Updates = 3, Size = 5963564 byte(s).
[SUCCESS] Update: Instance = 3, Size = 2555892 byte(s), Chunk Size = 256 byte(s), Major Rev = 255, Minor Rev = 255
GS=0x0C, ES=0x3002
[FAILURE] Transfer: File = C:\Program Files\ControlFLASH2\\0001\000E\004D\PN-176961.bin, Block = 237.
1769-L32E firmware
NowanH
Re: 1769-L32E firmware
Some questions:
a) If the PLC connected to an ethernet network? (it´s better connect the PLC directly to the computer).
b) Are you using any firewall/antivirus in your computer?
Some ideas:
- Try using the serial port of the PLC.
- Try using a lower firmware version.
- Try using other computer.
In the worst scenario, you need to send the CPU to the store.
Some ideas:
Id001x
Thanks for help! I'm already decide this problem! Few words about...
1) I'm try to connect with serial port - no results, computer don't have some firewall , AV - Avast.
2) I can't use lower version, cause program which i have was write in 19 version
3) I try to do it on another computer , and it give results from first trying!
