Hello! I have the following issue with KepServerEx v4.5 and Windows 7 SP1 32 bit. Under Windows user account with Administrator rights everything works fine. But under account with User rights or even Experienced User rights KepServerEx doesn't start. What should I do to solve this problem?
I can't leave PC loaded under Administrator rights, only under User.
Google search gives nothing.
Thanks. Any your help will be appreciated a lot.
Best regards, Oleksandr.
KepServerEx v4.5 and Windows 7 issue
Schtiel
Re: KepServerEx v4.5 and Windows 7 issue
You can create a shortcut to run it as Administrator. Use runas /user ... /savecred
new_user
Thank you very much for reply. I have tried but there wasn't any positive effect. KepServer (ServerMain.exe file) doesn't start neither by direct double click nor via shortcut or via "run as admin" method. Under account with administrator rights everything is ok. I haven't any ideas more ...
Schtiel
Are there any messages in Windows Log when it doesn't start?
You can also try to run it as Service:
http://www.kepware.com/Products/feature-ntservice.asp
cerebronico
can i get a copy of your kepserver 4.5? I have been looking for it a long time..
thanks in advance
thanks in advance
new_user
To cerebronico: no problem. Give me you e-mail and I'll send it.
Carlos
vlad2006gr wrote:http://www.ulozto.net/xnMrwg8/kepware-e ... 00-465-rar
Good luck!
cerebronico
Binary01
Thanks Carlos
xflash
great thanks to Carlos!
