i have a problem to communicate my micrologix 1500 plc with my pc . first i have a downloading cable issue i sort out this issue and succeed to establish a connection between my plc and pc (rslinux). now i have to upload program from plc to pc but i used software rs5000 is not for micrologix 1500 (LRP ). then i go on alen bradely site nd found one software for micrologix 1500 which is emulator when i run this software it gives an error not supporting with your operating system . i am using wind 7 home premium 64 bit .
now my question is that can i upload program by using RS5000. and the second question is that any other software which comptable with my operating system wind 7 home premium 64 bit.
or any other soloution for my above problem.
thanks.
micrologix 1500 problems sofware
NowanH
Re: micrologix 1500 problems sofware
Firstly, you need to use RsLogix 500 to be able to download or upload applications from Micrologix 1500:
http://www.mrplc.com/kb/How-to-Connect- ... 29_65.html
RSLogix Emulate 500 only works on Windows XP SP2 and Windows 2000 Pro SP4:
http://compatibility.rockwellautomation ... 0059,50183
