I have a machine with an 1747-L541C 5/04 CPU - 16K Mem. and it is using the DH+ port to communicate with a PanelView 2711-B5A8 PV550
The machine works fine, but suddenly happens strange things and I think that could be the free memory.
The actual values are:
Memory Used: 9699 Instruction Words Used - 4143 Data Table
Memory Left: 735 Instructions Words left
Which is the recommended free memory capacity?
Another question: 9699+4143+735=14577 where is the missing memory if the CPU is 16K?
In case that I need to increase the memory, should I change the cpu for an 1747-L542C 5/04 CPU - 32K Mem. o what else do you recommend? (I need DH+ for PanelView)
Thanks in advance
