[?]: software for programing Siemens 115U CPU
lapoule
Post by lapoule »
Hello everybody,
I find the software for programing & connection to a Siemens 115U CPU 942B.
It's possible to have a link ?
Thanks a lot.
( Sorry for my bad english )
All_exe
Re: [?]: software for programing Siemens 115U CPU
Post by All_exe »
Hello. Yes it's possible I did it some years ago. You need step5 (v.7.23 with hf) software and converter rs-232 to TTY (current loop interface) which you can do by yourself from here. And may be read Programming in Step5 book wrote by Berger. All of this could be found here. And one more I can do it only on Windows XP or less, on forward versions nothing was connected. I have manuals about 115U: over 600 pages about. If you need it or anything above (program or book), I can upload it, because i don't know if this books are here, I think it should be.
dekor
Post by dekor »
HI,
you may use Step5 on Win7 but you will need a small free utility called DOXBOX.
Also you need a good USB RS232 converter( for example by FTDICHIP company).
You may also use PG2000 software, is running on windows XP.
Success!
dekor
lapoule
Post by lapoule »
I test next week
Thanks for all !
