has anyone a serial and configuration sequence for factorylink 6.5.0? I have installation package, but can't install without these codes.
Or is there a workaround to install without these codes?
I want to analyse a FLink project to convert everything to cimplicity.
Best regards
FactoryLink v6.5.0 Serial and Configuration Sequence
tvk2650
Carlos
Re: FactoryLink v6.5.0 Serial and Configuration Sequence
test but I am doubt if it works, if it works you have one month of active communications.
119931MP
AMTU 69W3 UU5D 4PEU V6J2 6THY BKDR ADET BC
115110NA
B7IN GD2H Q45R PDDN VU3I ENSD TAEF BAK8 3D
tvk2650
unfortunately, it doesn't work.
I got a messagebox "Configuration sequence incorrect and not accepted"
tvk2650
Is it also possible to virtualize the Factorylink PC? The customer says it is not possitble to covert the physical machine to a virtual one, because of hardware encryption of the Factorylink package... (not possible to run the application after converting to virtual machine)
Is there a way to solve this problem?
