Hello
I have a problem with Wincc 7; when I open an application or I create the following message appears:
Starting a server failed. Verify your DCOM settings.
OS WIN7
Thank you for your help
[?]: WINCC 7: Starting a server failed
Schtiel
Re: [?]: WINCC 7: Starting a server failed
Try to apply the following REG file:
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Ole]
"DefaultLaunchPermission"=hex:01,00,04,80,64,00,00,00,80,00,00,00,00,00,00,00,\
14,00,00,00,02,00,50,00,03,00,00,00,00,00,18,00,01,00,00,00,01,01,00,00,00,\
00,00,05,12,00,00,00,00,00,00,00,00,00,18,00,01,00,00,00,01,01,00,00,00,00,\
00,05,04,00,00,00,00,00,00,00,00,00,18,00,01,00,00,00,01,02,00,00,00,00,00,\
05,20,00,00,00,20,02,00,00,01,05,00,00,00,00,00,05,15,00,00,00,a0,5f,84,1f,\
5e,2e,6b,49,ce,12,03,03,f4,01,00,00,01,05,00,00,00,00,00,05,15,00,00,00,a0,\
5f,84,1f,5e,2e,6b,49,ce,12,03,03,f4,01,00,00
"LegacyAuthenticationLevel"=dword:00000001
"EnableRemoteConnect"="Y"
"EnableDCOM"="Y"-
neutres1958
Re: [?]: WINCC 7: Starting a server failed (RESOLVED)
Hello Schtiel,
It worked, thank you very much for your help
