Hi All,
I am newbie to PLC AB.
What software and programming cable that used for upload program from AB PLC 5 ?
Can the programming cable made by our self ?
Any special advice ?
Thank you.
Upload AB PLC 5
prushmere
Re: Upload AB PLC 5
Howdo,
You will need RSLogix5 & RSLinx software and an RS232 cable as a minimum. There are other connectivity options available depending on the PLC5 type, but the serial cable will probably be the cheapest option for you.
Dedy aiza
Re: Upload AB PLC 5
that right....,, you can use serial cable RS232 or USB to DH+ interface for download and upload, if you use PLC5 Ethernet, first you can download with USB to DH+ and set IP address and then you can upload/download or online with ethernet (UTP cable )
RSLogix 5 for PLC Programming and RSLinx for communication interface to PLC5
prushmere
Re: Upload AB PLC 5
You couldn't really do more to confuse this guy if you tried, eh?
