Greetings
Is it possible that the card has ETY110 telemecanique premium plc is a plc information other information sent or received from other plc?
Thank you
industrial ethernet(ETY110) network
Re: industrial ethernet(ETY110) network
Module ETY110 possible to use
- Modbus/TCP Client or Server
- UNITE TCP/IP Client or Server
What function to send or receive data coding should I use?
Can ety110 cp343-1 binds to and Siemens with telemecanique connected?
1. ETY 110 TSX Premium has a built-in Modbus/TCP Server, does not require any function call in user programm.
2. In Simatic 300 use Open Modbus TCP or implement the protocol.
tanks
Do you need a special setting in the network card?
Need to use a specific function is?
I use PL7 V4.4
I use PL7 V4.4
ETY 110 TSX Premium has a built-in Modbus/TCP Server, does not require any function call in user programm and any specifing setting, only IP address.
