I have searched the answer to the question that keeps bugging me, but with no luck. I would like to simulate plc and panel configuration on my PC.
I have successfully simulated plc with basic panel in TIA Portal V11, but i dont have the option Start Simulation(it's grayed out) with the multipanels(MP377).
I'm curious if I'm missing something or the procedure isn't that simple? Thanks in advance with any help you got!
Forgot to mention installed software versions:
TIA Portal: Version V11 SP2 Update 5
Step7 Professional Version V11 SP2 Update 5
Wincc Professional Version V11 SP2 Update 5
I managed to simulate panel over Wincc Flexible Advanced 2008 but I'm still curious why the TIA portal simulation isn't enabled. It would be much easier to work with all in TIA directly.
