For the first time in so long that I follow your / our forum, I come to ask your assistance in this demand, I have a zen 10c1dr-d-v2, which was recovered from a machine that was slaughtered in a factory already in there, and this is protected by password. In manual Omron says that it is not possible to reprogram this "plc" with out the inicial password, my questions are:
- Is it possible to give new life to this "plc"?? or it is better to forget the issue and send it for recycling??
- If the answer is affirmative, how can rejuvenate this programmable relay??
I thank all the help possible to doubt this.
Many thanks to all who can help.
Rui Silva
Omron Zen programble relay locked
rualcosi
mohdabshr
Re: Omron Zen programble relay locked
if you have omron zen cable you can used omron zen password release tool from this link:
http://cpu13.ru/contents/files.php?&dir=n00/n40
rualcosi
Thank you for the reply, at least it is a principle to be able to recover this programmable relay, but unfortunately do not have the communication cable, but I am able to learn from someone who has, so I'll pass the weekend and then I will test soon this tip.
Again, thank you for your attention
Rui Silva
Rui Silva
