Modicon TSX Micro Nano
Hi!
I need to make some changes in Modicon TSX Micro Nano but I don't have program cable and software too.
There are someone who know the software that I should have and the cable that I should buy?
P.S. I already have the program code of the PLC that I will work with.
Thanks for all your attention and sorry my bad English!
Re: Modicon TSX Micro Nano
I think you should use PL7 software
Original cable is TSX PCX 1031, you can also do it yourself. To build cable you need Male 8 pin mini DIN connector and RS485 converter - check pin-out in documentation. I recommend to use PL 707 Win
PL707 Win
PL707 Win
First Thanks for the answers.
To avoid the risk my boss decided to buy the cable, the PLC are in client's Factory (so we cannot travel 500km taking the risk of the cable fail), we ask it to a supplier and tey recommend TELTSXCUSB485 and TELTSXCRJMD25. I will get them this afternoon.
About the software PL707 only open *.PL7 files and the program code that client send to me is *.TSX.
Do you know how can I open it?
It should works without problem.we ask it to a supplier and tey recommend TELTSXCUSB485 and TELTSXCRJMD25
I worked a few times with TSX Nano (TSX 07) and PL707 Win software but always with my own code. I would change file extension and check if it is possible to open in PL707 Win.About the software PL707 only open *.PL7 files and the program code that client send to me is *.TSX.
Hi
Schtiel is right you must use PL7pro v4.5 and it is already in the forum and I download your program TSX MICRO LINEA 3 and open it with PL7pro v4.5.
Thanks for the confirmation.
I'm trying to download it but all link are down.
Great!!! It's working =D
As you said PL7 PRO V4.5....
I'm running it on Windows 7 32bit with compatibility XP SP3.
the only problem is the license but I just will use this software 1 or 2 days.
About the cables I do not receive them yet, but when a get them and try I will say something....
Thanks Very Much.
Thanks Very Much.
So, where I'm trying to fight with an TSX3710DC PLC.
I'm using the cables TSXCUSB485 + TSXCRJMD25 and PL07 v4.5Pro.
I installed a lot of drivers to recognize the cable on windows XP (TSXCUSB485_Driver, MODBUS Serial) as I saw in some manuals, but I still not communicating with PLC, I think that is missing some points to do but I don't know what.
Can someone give some help? Like communication parameters, address that I should try to use, drivers that can be missing, anything that can help please.
Thanks Again.
Thanks Again.
in your plc program I see the configuration for Chanel 0 is unitelway link so you must configure your unitelway driver not modbus to communicate to plc ,search for unitelway driver v1.7 IE18 in your driver manager.
good luck.
good luck.
Yes, you are right, but what was missing is explained on link below
http://www.infoplc.net/foro/showthread. ... -tsx-micro
After done all of this everything was working perfectly.
So this job with TSX Micro 27 are done.
Next step is TSX Micro 17 waiting for me
.... They wanna kill my brain ^^
Do you recommend any software for this version?
see this link for pl7-2:
ftp://81.136.231.145/Old%20PLC%20Softwa ... L722D1.ZIP
I cannot download it, always failing.
This is manual not the software
Hi
in the first link read it complete you will find attachment for the software pl7-2.
i cannot download the link
, always failed please relink again, thank U
