[?]: unpassword XINJE PLC
ongtho123
Re: [?]: unpassword XINJE PLC
Hi, i tried it with FX unlock password but not success
, Have you got any advice for this case?
hmohamed
xinje PlC have a function (secret download) which u can not upload again
ongtho123
Thank you hmohamed, yes if xinje activate securedowload the program will show "Program code not exist".
I have question, in Xinje PLC when ladder too long (more than width row), how can i connect it like i did with FX1N or FX1S of Mitsubishi, I use GX Deverloper.
Regards
Regards
arm1612
Hi All,
I have Xinje XC3 PLC and it was downloaded by Secret Download. I have PLC program but i not sure if this one same with downloaded program. How can i compare it. Anybody have this experience before ?
milanjelikic
Hi all,
I am new here and was wondering for help about xc3 xinje plc.
1. if someone is greatfull to make short program in ladder of xc3 where i can use signal form encoder ( use for measurment of angle to 270 degress) that is will be nice. http://www.sah.co.rs/gts06-0p-ra1000b-2m-5222.html
2. how to connect encoder to xinje is that one of terminal "X" (input terminals) or it is A, B terminal near outputs ''Y''. ( Encoder has 5 wired (black - ; red +24v; green and yelow for signal; and 5th is ground)
3. The next problem i has it is comunication, when i try to download program to plc he sad modbus problem; i try online watch status inputs and outputs all working, i try to uplot program - work good .... what can be problem? i was use rs232 to usb converter, can that be problem?
TANKS IN ADVANCE all help u give me it is usefull!
TALEBABDELAZIZ
How to delete a password for XINJE PLC
Toms
For some models, the password of Xinjie PLC can be obtained through NAND BIN data
kawon53
ongtho123 wrote: Sat Jun 29, 2013 2:18 pm Thank you hmohamed, yes if xinje activate securedowload the program will show "Program code not exist".
Regards
hmohamed wrote: Fri Jun 28, 2013 11:08 pm xinje PlC have a function (secret download) which u can not upload again
mohammed ahmed
i have proplem when I make a connection with a plc xinje unit, I get a message "program code does not exist" Maher is the reason for this
mohammed ahmed
i have proplem when I make a connection with a plc xinje unit, I get a message "program code not exist" Maher is the reason for this
Tvhuy
Hi, does anybody have tool to crack plc xinje ?
I have plc xinje but it in lock, so can not access to copy program
Please help me.
Thank you so much
Please help me.
Thank you so much
rakeshhc
Hi, Did you get any solution? need help on cracking/removal software for Xinje XD5-48T6-E
